I got away from builds and only have the Crew and the Oath on my Kodi. I know with builds you get all the pretty backgrounds and such. Is there a way to do this for single addons so you don’thave that blah blue ? Thanks
Hi @Remy
Yes, if you want help, let me know.
I have test drove a few skins and an currently using Metropolis.
If you are using the stock build you can go to the GEAR on the menu then Interface then configure skin then background then click on use custom background and give it the location of the background. This won’t give you the slide show of backgrounds you get with other builds. You can also pick a different skin which give you the flexibility of backgrounds that change after a period. I am using the Aeon NOX: Silvo works great.
Sal
Thanks! I’ll work on it today
The Aeon Nox skins are nice.
