Add for old movies
Hi hopefully you’re all well
Hi I was wondering does anyone know a good
Working addon for old movies ie 80s
Tried the common addons
But no streams available
Cheers j
You should get real debrid.
try turks lots of old movies on there
I use real debrid
With homelander. And
The crew but no streams for old movies
There are a lot of free apps that show a decent selection of older stuff. Amazing Classics has older movies/shows, Tubi, Pluto, Xumo, SlingTV (free), Peacock, AiryTV, Crackle, etc. A more premium source would be Stremio, as it has a lot of hard to find stuff. I never had good luck with Kodi Add-ons for older stuff.
Also, IPTV services have VOD and 24/7 channels of a lot of these.
I have good luck for older stuff on Zuul and Ezra.
If you dont mind ads theres amazons FreeVee which is loaded with oldies etc…and dont forget Crackle and Tubi :+1:
The Film Detective has some great stuff.
If ya got kodi installed get the chains addon from the crew repo. Inside the chains addon is a section called retrowave lots of old stuff in there.
FidoK19 has 80s movies and more.
http://fantazyrepo.uk/repo
