Ad-free APKs for Firestick
I use blokada with bee tv gets rid of the ads
Tried the free version of Blockada previously - didn’t work very well. Are you using the paid version?
Does anyone have an answer to the above question???
OnStream? No ads I’m aware of.
OnStream seems to work OK. Interface is a bit clunky but it works and no ads.
Tried several others on Troy’s “Ten Best List”… OceanStreams, HDObox, Cinema… all have flaws that make them basically unusable (try them and see why) and all the rest have ads.
SO OnStream it is. Thanks Miki !!!
uk turks no adds works really well
Ya, for some odd reason since an update a week or so ago it takes longer to load. But no looking for sources it just works.
GET SYNCLER>>>>>>> : Thats all u need…& it’s straight forward…
Lookup the troypoint tutorial so that you can install it properly
I would tell u to use an adblocker i use that on my boxes and on my phone. When u use adguard that takes away all of the ads on apps and your internet. So always usean ad blocler.
If you don’t use a vpn, try an adblocker. I use official Cinema HD, BeeTV, and FilmPlus with AdGuard (free, but their vpn is pay) and get no ads. Go to APKTime (enter 250931 in Downloader for this store) to install Adguard or other ad blockers and many other entertainment apps.
I tried adguard but couldn’t get it to block the ads on BeeTV or FilmPlus. However, I was able to get an older version of Blockada to work. So I think that will be my backup for relatives who aren’t going to use a VPN on their firesticks: OnStreams or BeeTV/Filmplus with Blockada v4.
Troypoint Insider is a great resource for us “cord cutters” :wink:
OnStream is definitely my favorite APK👍🏼
How do you clear real debrid downloads.
Thanks
You have to log into your real debrid account on line. Then go to downloads. Then at the top right of the list click the red X>clear all.
Thank you. And thank you for all the useful information you give to everyone
I’m trying weyd. I think it’s $5 for 3 months works great no ads the links are great but you have to use real debrid.
I had onstream, it worked great however when i scanned it on defsquid it came back red saying it is a harmfull app, so i deleted it
A lot of apps like this are actually safe but contain code that triggers reactions in antivirus programs. If you’re careful and sensible, you should be OK.
I use the modified AdGuard 4.9.32 ad blocker from APKTime on my OS7 and OS8 Firesticks but have several OS6 devices (Firestick 4k Gen 1) on which it won’t install (get a “parsing error” when I try). So I installed the regular version (4.8.32 is the last one that will install) which installs on the Gen 1 4k stick for the 7 day trial. After 7 days, it’s supposed to revert to AdGuard Free but mine wont load when I try to run it. just takes me to a login page which errors out before I can log in. Cant run it so can’t get to any settings to see what might be going on.
Anybody use AdGuard Free on their Gen 1 4k sticks and getting it to work???
EDIT: There are several posts on the internet with exactly the same issue so there’s something going on here
