Hiya everyone.
I’m having issue’s remotely connecting to an Android box (X96 Max Plus). I’ve configured it within my home network OK but when I try to connect either via a back up network (I don’t have this anymore) or a Tethered network using mobile data on my mobile phone it won’t connect and give’s me an error message that says ‘Connection Error. Vysor installation on Android failed. You must ENABLE “Install via USB”, ENABLE “USB Debugging (Security Settings)”, DISABLE “Verify apps over USB” in Developer Options on your Android’ with the options saying ‘More Info - Retry - Cancel’. Now the last 2 things it says must be done are set correctly but the 1st must of ‘ENABLE “Install via USB”’ isn’t in the developers options. I’ve searched around but I cannot find solution and even when I click on More Info it’s a link where people have said the same but there in no solution there and the thread has been closed Vysor can't install APK or control MIUI devices · Issue #833 · koush/vysor.io · GitHub
I know Troy said in his video guide to Vysor then he’s installed it on Android’s boxes and it works OK but as I say this box is giving me issues so any help would be very much appreciated please.
Many thanks in advance.
Pete.
