I find that most 4k movies/tv that I choose have a red/purple hue. I use cinemahd. I tried using vlc and max player. Some do come in fine. I don’t know if there is a certain codec it is trying to use that it does not like. It happens on different sources(magnet,kickass etc) Audio is fine. Thanks for any input.
What I believe is happening is the uploader has turned on color blind mode and uploaded the show or movie that way.
Best bet it to change to a different 4k link. Happened to me on a 1080p movie. Threw me off for a second.
I came across that recently too. Probably the same movie. It was a newer one. Just switched to a different link and it was fine.
