4k max finds nothing in app store
I have issues with accessing some sites Like Amazon as well. But that isn’t because of the VPN but rather the ad blocking addon in the settings of the VPN. Amazon , and similiar sites, are ad driven after all. So if I know I need to go to those sites, as I often do, I turn off the ad blocking module, until I’m done, and then turn it back on. A royal pain, but ya get use to it.
Amazon app store will not work for me unless I tunnel it around surfshark.djetsons said he had same problem.
that might be the problem also cause I did have cleanweb turned on.
it would work for me after a reboot I guess because it was going through before the SS could get started back
Try turning cleanweb off as I have never had issues accessing the Amazon App store with any active VPN, although I do admit I haven’t used SS for many months. If that does the trick then you know what’s at fault.
I recently had the same problem. All the channel apps were not available. I turned off surf shark no good turned off kill switch App Store is full and loadable apps. This is a new problem as the kill switch has been activated since the beginning.
