2026 has anyone found the best security cameras with solar panels that are compatible with alexa
@djetsons, Google these….
eufyCam S4….Arlo Essential 2nd Gen….
Ring Stick Up Cam Solar….GALAYOU 2K Security Cameras….SEHMUA 2K Solar Security Cameras…
AI-generated answer. Please verify critical facts.
My Blink cams integrate with Alexa quite nicely…
Just asking because I was using 3rd party security cameras for about 3 years. But until late last year or around the time when Alexa+ came out, I noticed my cameras stop working with Alexa. I could still view the live feed on my phone but Alexa kept telling me that it cannot show the camera. So not sure if its something simple to fix or do I need to replace all of my cameras. I have about 10 cameras, thanks.
I bought the Botslab two camera 4k system with AI, It works perfectly for my needs, no subscription required includes a sever.
I have one camera using solar and the other wired, I need to do some work to add the solar to the second camera so I wired it until next spring, too damn cold to work on it now.
It’s expensive but works well you can find it on sale, the primary app is a phone app but I can view the cameras on Firestick and my Google/Android TV devices.
Includes IR for night, motion detection, follow, voice and sound, detection zones and more.
Amazon owns both Blink and Ring so they will both work with Alex.
On the same thread, a slightly different question. I am looking for outdoor security cameras that run on rechargeable batteries. There is no power or sun to the places where I mount them. Also want a product with no subscription, and an Android app to view. I was using Lorex cameras, which connected by wifi to a Lorex hub, but the camera batteries no longer hold a charge. Any suggestions?
There are many options on amazon and walmart. I have a couple of solar powered security cameras. They work well. They are different brands though so I do have to open separate apps to view them on my android phone. You can install micro sd cards for recording. No subscription required.
This is very similar to the one I purchased. Cameras that list onvif can be viewed with android apps such as tinycam
Searched on Tom’s Guide site [ Wyze just made installing outdoor security cameras as easy as changing a light bulb | Tom's Guide ] and found a solution that fits my needs. Power comes from a light bulb fitting, which I have at back and front of the house. Bulb can be programed to stay on overnight. Works with or without a subscription (lowest cost plan with rolling 14-day cloud storage $20/mth/cam . Available direct or on Amazon. Alexa compatible app.
Roku is cheaper and their cameras are made by wyze. $9.99 per month for all roku cameras or 3.99 per camera. I have 4 roku cameras simply for the ease of use, and the cheaper monthly subscription. I had looked at ring, blink, tapo by tplink and roku was the best overall deal for me. They have battery cameras that run for months on a single charge.
Stay away from RING or any surveillance camera that charges to record. I just switched to a 8 camera setup and have full control. I took a shot and was surprised at how great the picture was and it integration. I bought the REOLINK brand. It’s been up and running for a year now with no issues at all. You can go all wireless or wired and even a combo. I’ve had security cameras since the 80’s and this one by far for the price and quality beat out my $5K system I had… very happy. If you don’t know, RING and the others allow the police, FBI or any other government agency to access YOUR PRIVATE cameras and recordings WITHOUT YOU EVEN KNOWING!! No warrant and when ever they want as long as it’s accessed from the dept HQ. This is in the US and specifically Connecticut, so I can only imagine what is done in other countries.
Check our REOLINK. No subscription and EVERYTHING comes with the kit. The recorder NVR, cameras cables, if you go wired. Everything and cheap. Best price and you are NOT surrendering quality! The wireless cameras are great and you can pick what type of picture. Wide angle, distance etc…
