Does anyone know how to add a soundbar in the 2023 Onn 4k streaming box? It gives you an option in the initial setup but I can’t find an option anywhere in the settings after you complete the initial setup. Thank you.
Probably in settings under Sound or USB or Bluetooth. Try in there.
Are you hooking the soundbar up via HDMI or bluetooth?
Thank you for the reply. I finally found it. I was under the “add a device” in the bluetooth section.
That’s great, glad you got it figured out.
