I’m trying to upgrade to 19.3 on my tv with a fire stick nothing will load after it’s done I turned off my VPN still nothing. When I go into the manage app it says I have version 19.3 what am I doing wrong?
I had the same problem, upgraded from Kodi 18.9 to 19.3. Installed as instructed with Downloader like in the screen above, but after installing, when I click on Kodi icon nothing comes up. When I checked on my installed apps on firestick, Kodi 19.3 shows up as being installed, but does not come up when you click on it to open… What’s up with that?
Hi @Ellie
Sorry it didn’t work.
Let’s try something.
Try to uninstall it. Then when completed, open Downloader, and in the url box type in Troypoint.com/kodistable
Once it completes downloading, click the install button.
Next, click on the Kodi icon, next click yes then let it open.
Come back here and let us know an update.
Hi @Ellie
Your welcome and glad it worked.
I only use just a few apps, it’s easier to keep things cleaned up and running smoothly.
I use Seren, The Crew, both with real-debrid.
Thanks for the question and mark your question as solved so others who find their way here can see what we did to solve this question.
Let us know if we can help again.
