I’m using Diggz Xenon on my Nvidea shield and I’m having trouble with it hanging frequently when I use the exit button to close. Is this a known problem?
I’m on a 4k Max and often have the same issue. I have to click the return or home button a number of times and then go to manage installed apps and clear the kodi cache. This must be a kodi issue as it never makes any difference what addon I’m using.
