Anyone else having problems with the wire guard protocol on IP vanish?several different times in the last month I have gotten a message saying they cannot connect to server the other two protocols work just fine thanks for any help
I’ve had similar issues. What has worked for me is to change the protocol, test the download speeds. Then I go back to wireguard and the speed usually gets way better. It’s only happening once or twice a week. Hope that helps.
IKEV2 does not connect on any of my devices. Wireguard only gives me 50% the speed as OpenVPN (TCP). I think it might be the ISP provider. I use Optimum. I contacted ipvanish but have no resolution yet. IKEV2 does not even connect on my Samsung Galaxy S7 phone using 4G.
Hello @Boligee I would suggest uninstalling your current IPVanish app and reinstall then try again. Just to ensure you have the latest version as they have made a lot of updates lately. It’s also important to note that some protocols might not work properly with your Internet provider. As @Therealsock and @Money mentioned, test out each protocol until you dial in your best speeds. For me, the best is OpenVPN (TCP) and I’m getting 130 Mbps - 150 download on Fire TV Stick 4K Max.
