Why wont Pluto load on android boxes?
Pluto loaded fine on old boxes and firesticks but if you try a new android box it will say this program incompatable! Thats from the play store the unlinked had a version that worked but they took it off! Where can I find an apk that will work?
Have you tried this one? …no promises tho
Pluto TV for Android - APK Download
Do you have Play Protect turned on?
There is another option. You could load the Pluto m3u in TiViMate or the IPTV player of your choice.
Pluto for your IPTV players. Playlist and EPG.
https://i.mjh.nz/PlutoTV/us.m3u8
https://i.mjh.nz/PlutoTV/us.xml.gz
have tried it with play protect on or off doesnt matter still says this program uncompatable go to the play store to download Which is where I got it to begin with
Hey @witw What kind of android box are you using that’s being so finicky? Pluto is about as mainstream as you can get…try the ad free version in Unlinked Store 96960000…
