I have troypoint app to download but Cinema is not there anymore. I was trying to update it but if I remove it I don’t know how to get it back. Also, does Xanax load slow for anyone else?
As a newer user be sure to use our search function as it has alot of answers.
Cinema is not on our rapid app any longer, if you want it you need to download unlinked code 12341234 it will be there.
Also that build isn’t supported anymore.
