I had installed Syncler before, and it said it was free with the s+ code, until whenever, hadn’t used my box for a while, came back and said it’s expired or something. I went to their website because I wanted to buy premium, but when I try, it says it’s free until another different time line, and to enter s+ again. It won’t work, and it is updated to latest version, so it doesn’t make any sense to me.
Thanks! There were some changes apparently, since I last had a chance to use it. There used to be a code entry, now appears that you just enter that code into the username spot.
Is there a cleaning app that clears out the cache of all installed apps on the Fire Stick with extended memory per your tutorial? Thank you for your sage assistance.
One last question, When using Syncler is it true that you don’t need to use a VPN provided you are only using Real Debrid links? Thanks for your sage direction, much appreciated!
One, I don’t really understand why someone pirated my thread with unrelated questions, and to Troy, not that I don’t mind free stuff, I just want to get a sub, so I don’t have to worry about it. First it said till the end of the month, now it says the s+ works till December 6th.
Hello @Anonymous and @olsaaronc I just went through setup process again after I saw your posts and the following link outlined on our tutorial is working fine on my device - https://bit.ly/syncsquizz
Thanks times 2, to ya both. I redid everything, and if you use all 3 links, just hitting return for a new line, you can use all 3 for the express, I believe it was. I read slowly, and it says, “one per line”, not that you are only allowed one link. I never read all of any directions, lol, but after doing that, I search for a show, and got 843 links. Luv my fellow cord cutters!
They Have a good telegram support so I would recommend go there.
I just pay for Netflix and the other ones I could really care less I got Cinema HD and other easie so forth.
