What's Working with Real-Debrid
I got a refund for 6 months I topped up with in the last week leaving about 80 days on my sub. I’m hearing if you asked for a refund, they will not let you buy from them again. :person_facepalming:
Here are my results:
VPN different locations are not making any differences.
I’m running RD and All debrid.
I get no AD results when connected to VPN.
I’m getting RD results on Fen lite, Umbrella, and the Crew with Kodi.
Cinema HD
No playable RD results and again no AD results if connected to VPN and Playable AD results if not using VPN
All RD results say “unchecked” as someone else reported.
Regarding AD, I am using the trail version, so I don’t know if that makes a difference about no results using a VPN. I kind of doubt it though. They say on the website using a VPN with their service is useless.
Using RD and PM. Plenty of sources meeting my filters. Both play fine using my VPN. I love that PM allows me to choose a server and speed test it. This allows me to choose my VPN server that is close to where the PM ones are for my VOD app and not only best speed but no buffering or glitching.
RD working for me in Stremio; living in Cincinnati, using PIA as VPN, logged into Baltimore servers currently.
For those that have AD and it wont play links in kodi with the vpn on. You can solve that problem by signing in to your ad account and go to “my account” . I have surfshark and that is one of the approved vpn. Once it recognizes your vpn, kodi links will load with or without vpn.
Updated Umbrella this morning on Kodi, RD is now working on all 4k and 1080p. Next reset the Crew now also working. Found out that you must close Kodi and restart for links to work. I’m also using Surfshark.
RD not working on Seren
Using IP Vanish on NE TX
Check “log” but can not find log for Seren
Using Cinema past few days. So far so good using non RD links. A few RD links came up this morning but I did not click on them.
My RD account was paid about 5 days ago. I was good until June 20 2025 with 6 mos plus 30 from Fidelity points. I asked for a refund within their 14 day period. Seren/Kodi does not give info but on Cinema it does, says I am good until 12-20-24 which would mean they are in the process of refund and are using my points. I don’t know yet as I have not received a bank credit nor a reply from RD.
I’m in NE TX and use Dallas for streaming but Atlanta for other things
NorCal loaded 2 addons to my Kodi. Umbrella and Twilight. Umbrella has alldebride and it doesn’t work, no streams. Twilight has RD and it seems to work just fine. I only use Stremio for TV shows and haven’t seen a issue yet. I don’t watch many movies or shows at this time. Side note, Umbrella did work initially when I installed AD to it but now no. I’m sure I need to make some tweaks
Closing Kodi did not work for me in Seren
Sorry to hear that Judy, is there an available update on Seren? My Umbrella and Crew both worked after updating.
Each addon developer will have to make the adjustments if they want it to work with RD.
I read elsewhere (not TP) that the Coalition and Genocide addons will not be updated to work with RD. Developer believes it would only be a temporary fix anyway. Who knows?
Umbrella Dev had an update and did a fix and it is pulling RD links for me today (in Red) along with Premiumize (in Blue) Who knows how long RD will be around but now I have 2 Debrid providers pulling plenty of sources
My refund is being generated!!
I’m going to try updating Kodi.
Im using Flixvision and my RD still working, I have Kodi with the crew at last check RD was still working
The crew is working again . almost all of my RD links are working now .
My Orion is working again as a scraper for RD using Stremio. That is good.
I hope the Feds aren’t reading all these tips of what is working. That is bad. :face_with_diagonal_mouth:
i knew this would happen…i still get all my content the old fashioned way…with a vpn and torrent client…i download and watch or read whatever i want in less than 5min…has never failed me in all these yrs and still working perfectly
I had two accounts and both have been closed or Expired. Lucky for me i only had a month left on those accounts. I used stremio and syncler both down right now/Apollo works great
