Good morning.
Syncler Beta implemented the first fix and became “Debrid Friendly”.
Then, a few days after 1382 update rolled out and got the stable syncler release Debrid “Friendlier”.
Good morning.
Real Debrid is working just fine on Stremio here in Canada.
API ? Hoq do i find out about this ?
API is Application Programming Interface. Usually addons for an app will have an API key that you must enter to activate it.
I read flixvision works with all RD links I’ve downloaded flixvision but my RD ran out when all hell broke loose so I’m just reading up on it now for the last say 25 days and read that and also maybe try clicking on a UK server that I’ve read that might help being that it being a different country. Hope I’ve helped I might just get my RD account topped up to see if all works. I like flixvision only used it a couple of times but it keeps your recent shows watched in order kind of like prime video. Hope I’ve helped
RD has been working good for me with my go to apps Cinema HD and Stremio. I have almost a year left on my RD subscription. I’m going to use it until it completely stopped working.
Happy Streaming
RD will probably be fine after that too. I plan on renewing until it’s actually not working
Ditto @Neo renewed RD for 3 mos. currently have addons on firestick The Crew, Umbrella, Elementum, Daddylive & Gratis so far all is good Know RD not needed for some of these just letting you all know what is installed currently on my Firestick
I’m moving from the fire stick to android TV. I have found that the fire stick is coming to an end. Can anybody give me any recommendations for apps, android box for around £200, etc? I am using RD and am very happy with Umbrella, and the work around. Do people use Kodi on android TV boxes? Uk based
As far as I know, any Android box, TV or stock, will run Kodi, Stremio, any IPTV player, etc.
I wouldn’t think that you’d have to spend 200 pounds to get a good device.
Ditto here…
Do you need good audio support? Plugging in to avr or just tv?
Ive just got the ugoos sk1, it plays everything. Its not google certified so if ya need netflix i would get another device.
I would recommend also the homatics box r 4k plus, supports dolby vision and atmos. This is google certified.
Any questions fire away.
@Anth thank you, I will look into the Ugoos Sk1! I don’t like Netflix, stopped using it 2 years ago, had a look recently, and its all the same… with more none English speaking films
I got mine from the link below it was £159 including delivery, no vat or import duties to pay. There is $10 off code UGOOS10 just enter that during checkout, it takes it down to £161.89.
Not too much difference PapaS, you got to pay import duties?
Thank you
Didn’t have to when I purchased.
In what way?
Just purchased Nov 1st the fire TV cube latest gen. for $60 out the door on woot.com refurbished 90-day warranty woot is owned by Amazon. Fire sticks are not coming to an end they’re just going to have new operating systems in future that will be more closed. Probably no side loading. Older units will still stay on the operating system there currently at. Sorry don’t see any there right now at woot.
