Hello…
I recently bought a new fs 4K and moved my old one to guest room. Anyhow, all my apps reloaded and I had a ton of space.
All of a sudden, despite clearing cache, using debloater, etc…-I have less n less space each time I look. No, haven’t downloaded any new apps … I’m stumped… could it be kodi 19.3???
Hi @ztrb @TP-Dracoo is correct.
According to your screen shot, with .98 of available space left, there are to many apps installed and running in the background at the same time to reduce that amount of available space on your Firestick.
Even if you forced stopped them running in the background and cleared cache, that isn’t going to free up much more memory.
As @TP-Dracoo suggested, if you want to keep them all, move them to a fat32 Scandisk, Otherwise might want to consider uninstalling some.
Hi…
Ya… I might have to do that… BUT the weird thing is THIS: I’ve had SAME apps since I’ve gotten new FS… With these same apps I had almost 2m of space at first!! WITH NO change/added apps, my space keeps literally shrinking each day… I’m stumped…
Thx for ur replies.
I’m about to wipe everything and reinstall cuz something is not right to me…??? I dunno?? Wanted to post here first to see what y’all think:)…thx again
…shout out n thx to u guys for ur replies to me yesterday ! It was such a simple yet huge issue in which I was somehow?? overlooking. Your replies gave me that simple “a ha/duh” moment…
think I was looking TOO hard for something else ‘wrong’ …ugh
I’m now going through files , apps and free fixing:)
I’m glad we where able to resolve this. As mentioned the firestick as low storage. Always be on top of cleaning it up and removing bloatware and unused apps.
Rest can be moved to a USB.
If this is resolved please use the solution feature.
