@DaveZerf Hey DZ, I’ve never looked at WEYD but just set up NUVIO and really like it. I’m gonna go look for a TP post on WEYD. Thanks.
If you try weyd and need any help give me a shout. Super easy fast to setup, add one url for the scraper, link your Debrid and you’re off. You can do this all in the app or remotely using their website. The Trakt integration is great including adding your own lists that you’ve liked on Trakt. Autoplay or not Autoplay. Lots of settings to go through and play with different things but you don’t have to either unless you’re looking for something particular. Has support on Discord and Telegram just remember don’t call it “Weyd” it’s “weyd”
Not the friendliest chap in the room but helpful when needed.
diggs zenon is all ready to use when you download diggs does great work on kodi builds
What PapaS said above, and under link filtering make sure both of the first two things are toggled on. Under Link resolving you can set up auto play or what ever it is called, I set mine to auto play after 10 links, I set the time to 20 seconds.
If you need a link for the scraper hit me up, I would post if here but not sure if I should.
I as well am fairly new to the Kodi experience. I’ve been able to get Umbrella and Crew to work but that’s all I’ve got. My question is that there seems to be a problem with umbrella movies being able to get the first option on the list to download IF it has Dolby atmos sound. If the following options don’t have Dolby Atmos then it plays fine. Is there something that I am not doing right in the fact that I don’t have Dolby Atmos sound available from umbrella?
I’m a big fan of weyd as well. It’s been my go-to for a time, also. I like this nuvio app now for older series that weyd don’t provide links to such as the 2008 Australian mafia series, “…”. No, it’s not as simple as weyd, but it’s free, and that can’t be discounted. As for Torbox, I bought a year’s sub for it and it was no use for me in Stremio, as it was always “fetching links” but never delivering them. Now it’s the main app for nuvio. I’m going to get the lifetime sub of weyd next month so I can see how it works with Torbox. Cheers
I don’t have Diggs loaded right now, but i do have Umbrella with both debrids. I always keep a working Kodi build in case I have problems with Stremio.
There could be several reasons. What streaming device are you using? Some Dolby Atmos files are too big for lower end streaming devices like Firesticks, cheap android boxes, etc. Make sure you have Audio passthrough enabled in your settings in Kodi. This is just a couple of suggestions. I have audio passthrough enabled on my streaming box. There are videos available for Kodi to address this problem on the internet. Just Google it and watch the videos for more in depth solutions.
The term ‘simple’ is subjective as what’s simple to one is not simple to another. You can’t go wrong with either Stremio, Kodi, or Nuvio IMO. This one might interest you if you missed it - Stremio vs Kodi: Which Streaming App is Better in 2026?
And I’m not sure if you’ve gone through our in depth TorBox guide but this has everything you need to know - How to Setup TorBox in Kodi, Stremio & APKs (Video Guide)
If you have paid weyd and not a rebranded panel, update your weyd to V 4.0.0 and you can use torbox without life sub.
Thanks for that tip.
Thanks for taking the time to respond to my question. I’m using the ONN 4K Pro and I also have the Firestick 4K Max. I don’t use the Firestick very often because of their obsession with making some third party apps unable to function. I have a Samsung Q90 soundbar that has 7.1. that is very highly rated for Dolby Atmos.
I will take your advice and do some searching on YouTube. Thanks again for your help.
Happy Cake day
@Reece Genius! My picture is good enough, my streaming is functional enough, my house is clean enough, my eating is healthy enough etc. etc…
Yes..if old “Mediocrates” creeps into ones mindset and they comply with his lackluster teachings, they are certain to at least maintain a “Ho-Hum, Meh, Whatever” attitude…![]()
Ho-Hum, Meh, Whatever…
