:+1: welconme to the group
welcome
Tx to @Powerfader for the fun GIF
And a link on where to buy it. I’m in the UK so won’t be easy to obtain
Are they good with syncler as well as Kodi
Continuing the discussion from All-New Walmart onn. 4K Pro Appears to be in the Works for 2024:
2 problems I’ve encountered that maybe is just the 1 I have or maybe it can get fixed with the next box. 1, the WiFi capability seems limited. It wouldn’t connect in the bedroom even if I connected to the extender. So it ended up in the living room with the hardware to connect directly to the router. 2, if I’ve watched several apps I have to go into settings and ā€œforce stopā€. I hope the new one will shut down the apps when I power off to solve this problem. I’d be interested if others have similar problems.
Its sort of nice,but will users be inundated with Walmart Ads down the road.
I can see a Onn 4k in my future…
Run syncler and weyd with no issues!
You can make a safe bet with that.
I’ve been on two onn devices for almost two years and although I have 5 firesticks, as they die they are the last. The Firestick just can’t compare. I do wish the onn had more storage. I did the USB storage rigamarole, and that’s just not worth the effort.
ā€œI recently discovered you can add Pluto TV as a PVR Client source and pull in those channels and guide to the Live TV section which I hadn’t done beforeā€.
Curious if this is documented in a step by step process to add through Kodi? Or if you have it documented? I’ve set up my Onn box but am still green to developing add-ons through Kodi and feel I’m missing out…particularly on the live-Tv side!
My friend got one, he bought it in the states, works really good
They are great, I got two of them finally in Florida last December. It took me visiting three states over a year to finally find one. I will absolutely look for this new one when it’s out if the specs and price make sense.
Well im dieing to check out the new version, there’s been lots of talk about it, im sure it’s going to be a hit.
The instructions below can be found on the Kodi Wiki page, just do a Google search for kodi adding live tv pluto pvr or something along those lines and you’ll find it. Here are the basic steps I took to enable/add it, and it works great!
This add-on is installed from the Add-on browser located in Kodi as follows:
  1. Settings
  2. Add-ons
  3. Install from repository
  4. PVR clients
  5. Pluto.tv PVR Client
  6. Install
Thanks very much! I appreciate it!
My oNN box works great very easy to side load
I hope HDMI 2.1, Bluetooth 5.1, 2 or more USB 3.1, WiFi 7.0 with one Gig speed and Android 12.
Four Meg memory and at least 32 meg storage.
This is my dream streaming device. Time will tell
…and bypass OBB restrictions.
Amen.
As well keep a great price point although I would suspect it will go up now that they have entered the market place in a big way. It’s a good product.
