Is syncler going thru VPN or not? If not, what do I need to do?
Thx in advance
Thx in advance
As long as the vpn is set up properly it is.
Agree Ron, it shouldn’t matter the storage location of an app. If a VPN is setup on the device, it should access the internet through the encrypted servers.
yep, unless the vpn has been set to bypass anything(syncler in this case).
Guess I have to figure out and make sure Surf Shark is properly set up which I know nothing about.
As long as you aren’t purposely “bypassing” Syncler, you will be fine. (by default, NO apps are “bypassed”)
Ok thx, I put them all in to route thru SS. Thx again for the answers all. Helps a lot.
Also so I should make sure SS is installed on device and not flash drive? Even tho it is do t wanna make that mistake when I do my other two.
It will work better if its on the internal storage, for that matter always put most frequently used apps on main storage(internal)
Got it and once again, thx for the good info.
