Can anyone tell me how to get the voice search fixed on Kodi add-ons, I am using an Nvidia shield and ever since I updated whenever I want to search for a show on an add on, When I press the circle on the remote the Mic pops up momentarily then disappears, It used to work fine until the most recent kodi version. Thanks for any help
As far as I know you have to to use external apps to do that, and to add to Kodi add-ons.
For Kodi there is a solution for adding voice search, but this is to technical and more complicated than just changing some settings.
For NVIDIA Shield check this official link voor settings voice search…
NVIDIA Shield Voice Search
But you can try this solution from how to geek by installing the app.
https://www.howtogeek.com/253506/how-to-control-kodi-with-your-voice-and-more-using-yatse/
