I have this app on my TV and it works fine, but on a new TV I cannot get into the top right corner to select. Has anyone else encountered this and how did you get around it? Thanks
Never heard of the app but most likely you need a cursor(pointer).
Tried that, the top right corner with the search that shows up on the other tv’s does not come up on the new one.
try adjusting the tv screen resolution…
What device are you using? On the firestick you need to use the screen scaling. If it’s a stick, let me know and I’ll give you instructions.
I am using a firestick
Excellent. Go to settings>Display & Sounds>Display>Calibrate display> and set the arrows to touch the edge of your screen. Hopefully that will resolve your issue.
Thank you very much
Appreciate it
