Upgrade Existing Shield?
I have owned the 2015 Nivida Shield for several years now. I bought it used from eBay. I haven’t had any issues, but I am curious…
Would upgrading to the newest Pro Shield gain me anything that would make me “happier” with my streaming experience?
I also have three 4K Firesticks and a Mibox S. None truly compare to my Shield :shield: !!!
Welcome. Hard to beat the best. I would stay put until they come out with a newer model. If it aint broke don’t fix it. :+1:
That’s is probably very good advice!! Thanks!
Update yes! Upgrade probably not worth it unless you’re gaming. I’d wait until there’s a new model, current one is getting left behind somewhat compared to new devices.
Only upgrade I will recommend is change the hard drive to a ssd
