Updating Wolf Launcher
Does wolf launcher update automatically? Thanks
Not that I know of. I will have to look if a new one is available.
Hey Jojo,
No, AFAIK the apps you side-load do not auto-update unless the functionality to check and update is built into the actual app itself.
But if you install the Troypoint Rapid App Installer, it should always show the latest version available.
  • Note : You can get App Info including version by highlighting any app and choosing File Info from the pulldown menu.
Hope this is helpful.
Capp
