Updating Superman build
I keep getting a notification that there is an update and then there are 3 options: fresh install, regular install, remind me later. I have clicked both install options and nothing happened. I waited, tried turning on and off…nothing. What am I doing wrong?
I don’t know about builds, but normally in kodi in the settings menu, go into system/ addons, and make sure that the update toggles are selected to yes, otherwise it won’t update.
Same here update says new version 1.6 but again clicking nothing happens
By the way I have two units if I refresh on one I lose all past favorites and settings but on other firestick it updates and everything stays in place go figure…
Yesterday got same update ignored it but did go to cmanwiz…clicked builds scrolled to Superman build yes there is a 1.6 update…I downloaded note only freak build was noted …it updates but erased all my settings and favorites…
Not freak build but fresh build sorryemphasized text
