Updates - How to - FireTV & Cinema
Two Questions
  1. How do you find out what release you have for Cinema & FireTV?
  2. How do you update each of them?
    Thanks in advance
For Cinema, upper left of opening screen is what I refer to as the hamburger icon (3 stacked lines), click and its listed there on top. Regards to updates, they’ll be a notification whenever you start program.
FireTV, click settings/my fire tv/about and all the info is on the right. Also from there, you can scroll down the list and check for updates if desired.
