I know this sounds elementary but when you uninstall an add on via my applications section on the firestick, will that remove all the extra repositories associated with the original install? Hope that makes sense and thank you
Hi @umgawa1952
In a word, yes. However, if you want to make certain, go into X-Plore app and double check to see if indeed it removed everything.
Thank you for that advice. There are so many add ons out there I wanted to try them but I have to delete one before adding another one due to limited capacity on the firestick. When installed, there are always some addition items that get installed with the add on and I want to make sure they are also deleted.
Thanks again.
