Unable to view any channels on Sportsfire on ONN devices
As of this morning I can no longer open any channels in Sportsfire. Does anyone else have this problem, and is there a fix? This morning Streamfire is having the same issue.
Mine is down too. I uninstalled app and norofire don’t work either
YouTube has been reporting this for a couple of days. Use your favorite Unlinked store for multiple options, all of which will be referred to here as Crap Apps. Suggest EMDYOUTUBE or FIRESTICK stores.
Best fix is investigate IPTV options (patrons only) that only cost a few dollars per month.
I was having the same trouble, I uninstalled Norofire. Unable to reinstall now,
This is the latest codes on the tutorial but they don’t work.
Downloader codes have changed for both Streamfire and Sportsfire. Use these codes instead when instructed via video below.
Streamfire Downloader Code: 6647940
Sportsfire Downloader Code: 8204342
Yes, it’s currently not working. This has happened before. Stay tuned
Same with me
Ditto
I was looking for some direction on this too, no bueno for me.
As has been said many times and in many threads, it is down and may be gone.
:+1: Same Here…
welcome
So this may be tied to the Operation Red Card and Offsides shut downs?
I HAVE not found a fix. Football season coming, pay tv.
Neither of the fire apk’s working on my fire sick 4 K max’s
Nope. It looks bleak
Is there a similar app. Streamfire is the only app my wife and I used 90% of the time. It was our go to.
The best fix is an iptv sub. There are other crap apps you might find but dependable NO.
Try SportsX
Downloader code 3220241
It worked on my end. Thanks
