If using vpn turn it off while downloading whatever you want. Then remember to turn back on to stream.
You say the followingā¦
āi have tried 4 times and says kodifitzwell repository addon installed, then click on install from repository and says could not connect to repository.ā
It doesnāt sound like you installed the ZIP before trying to install from depositoryā¦
After installing the Kodifitzwell depository, go to Addons and āinstall from Zipāā¦once thatās done, āinstall from depositoryāā¦
Itās pretty basic but maybe you skipped a step?..
The repositories are down both.
Working for meā¦
Click on respiratory, zip file is gone. Iām using 19.5 because of permissions. I havent tried other device with 21.2
I am using latest kodi version so not sure tbh.
Yeah just checked 21.2 zip is there. He also has a new module for scrappers but I donāt see it
Dev has just added torrentsdb to aiostreams. You can see these in sources and enable them along with any others you might need.
Also the Rd+ and Alldebrid+ are still available in My services if you use any of those Debrid services.
Also added magnet scraper. Differently one of the best out there. Used to be the awesome venom
Didnāt see that on the POV change log tbh.
Funny thing not many people read those lol. Yes I believe it was in lastest driadis update log. Thing is you canāt change it like umbrella. But I suggest opening magnet scraper and turn on most of them because by default thereās like 2 that are on
