Heya I recently bought a new tv (Samsung) i realised that on my app on phone with smarters i cannot smartcast on this new tv . I play a channel and i can only cast on my old tv do you onow Why?
Try asking Miki. He had a similar situation with new tablet, but seemed to find a solution. I am certain he will try to help you.
Îśiki is? Im new on site have no literally Idea
I couldn’t use my 4k Max for screen mirroring. I had to go into the input settings using the tv remote and select “TV” as input, then the screen mirroring worked perfectly.
