šŸ† TorBox Setup MasterClass for Nuvio, Stremio, & Kodi
I have been using Real debrid for years but it appears that now when I use Kodi and try to open up a movie, nothing happens. Is this because of Real debrid and would this problem be solved if I use Torbox.
Simple answer is yes.
thanks
You’re welcome. Don’t be afraid to ask any questions you have. The insiders love to help. Have a buffer free night.
I take it that’s because you have an extended subscription? Do you get many (any) links?
Thank you for the excellent video. My Real- Debrid is coming up for renewal so I switched to Torbox. I hope I do not need both services.
50/50 It says it is there but when i attempt to view, nada
Thank you so much for everything you do and the instructions!! I’ve been an IPTV and Cinema user since 2016 or so. When cinema left us I was heartbroken. LOL. I got Nuvio set up on all my home and travel devices but then I refreshed my API key by accident and it ruined everything. Thanks to this video I am back up and running in Nuvio. My family thanks you! I am soon going to be helping my coworkers/friends with Nuvio setups. Have a great day!! Thank you again!!!
@cplank00 Debridio for $10/year makes Stremio and Nuvio the best they can be.
@cplank00 HAPPY ANNIVERSARY…
It’s Time For Cake !!!
I have more than one profile setup in Nuvio. If I use Bootstrapper to setup addons in one go, does it replace all your addon setups for all profiles or can you select an individual profile of your choice?
Also I would hate to blow away my primary profile and all my watched history and library of movies and shows. Or does it not affect history and library?
Seems like I get set-up and something new comes along. Got my buzz box, premiumize is paid up, surfshark. All the latest not long ago lol. For me Kodi and Fen light is working just fine. Crew for baseball when game is unavailable regular channels. All the different repositories for hard to find shows. Thanks Troy, I’ll keep reading your good works.
I saw the 5/20/26 post ā€œNuvio Removes TorBox Debrid Integration.ā€ Does TorBox again work with Nuvio? Wanted to check before trying to figure out how to setup Nuvio. TIA
They no longer have the ā€œintegrationā€ for TorBox, but it still works in any addons you have installed in Nuvio and have the TorBox API key authorized in them. The idea was to have one integration and not have to do it in every addon, but that began to show that while the thought was good, the reality wasn’t.
Keep in mind you can use Premiumize with all of the apps that I show in the video above. Where I choose TorBox just select Premiumize instead.
Please watch the video above. Yes it works and I show that in the video.
Watched the video and he only downloads umbrella in the video. Has anyone added any additional addon to the kodi like the addons on Xenon 2 thanks
I used an Amazon gift card, purchased with cash. Coordinated with a person from customer service. I was up and running within less than an hour. Didn’t have to provide any PII.
After Troy’s master class video on Torbox installation in Stremio, Nuvio and Kodi I purchased a one month trial of Torbox. I use Kodi so I tried installing it in my addons. Starting with Umbrella, POV and Crew no short codes will install from my computer or phone camera. I get to the code input page, enter the supplied code and continue won’t do anything. Fen Light Unofficial and Fen Skeleton allow entering the API Key. For both of those I entered the API Key and both accepted Torbox. The other addons don’t offer the API Key option.
I hope someone can help. I never had problems with Real-debrid short codes. I’m prepared to try any suggestions because it’s not worth it if I can’t sync with all addons.
Sonny
@SonnyL Try logging into Torbox in the back ground on your phone and THEN scan the QR Code you get on the TV screen and it should work. Sometimes you need to pause the VPN on your phone too.
