Newbie with Tivimate here. Have Tivi downloaded and input the m3u form my tv supplier. It shows all the channels list, but no channel info in the EPG? Any ideas what I did wrong? Thx!
Hello @rikkikittie when using the M3U setup, you also need to input the EPG url as well for the provider. Search their FAQ or documentation or submit a support ticket to get that URL.
Break out the URL, Username and Password from the M3U and add it as a XCodes.
Then, assuming your provider has an EPG, it should just load it.
Give it a few mins after starting because it might be a lot of data.
You can check the status in the EPG menu.
