can you use Dynalink Android TV Box, Android 10 with Tivimate i do not see fast forward on remote
I have a Dynalink but have not installed Tivimate on it, I use Tivi on all my firesticks. I think if you click the down button on the remote it will navigate to the onscreen FF / pause and RW buttons. Give it a try.
Hello @Jaxx2015 even without the fast forward button, you should be able to click the select button on the remote to pull up the playback bar and then use the on-screen buttons or scroll bar to fast forward or rewind.
thank you very much Ray
