I don’t have it up right now but there were 3 results. Try all 3, one works.I just checked. It was the LimeTorrents one 10.13GB
I tried the Lime torrent but it wouldn’t work .
Odd, it plays for me. Try all 3.
The book is a literary classic and the story doesn’t really change. I liked the 2002 presentation very much. Pick either one, the story is worthwhile.
I did try all three . They would open but that’s it . The other movies worked in the app thow .
No idea. Worked perfectly for me on the Shield Pro.
All the RD links work but none of the free one’s don’t work in all the addons I’ve installed . Maybe reinstall the app ? I am also running Nvidia Shield Pro .
There are numerous iterations of this Dumas classic tale. Hollywood began producing it since 1934. The 2002 edition is free on Hoopla and for rent on Prime and Apple. The 1975 edition is on TUBI and many other FAST apks. The 2021 edition is on Fawesome.
Use an app like ReelGood (avail. on most app stores) to find your movies and where to watch them both free and paid apps.
ReelGood works
I use the RD links 99% of the time. Same thing in that addon, I have RD authorized. So maybe that’s why it didn’t play for you. Sorry but I don’t know anything else that would cause it not to work for you.
In Media Fusion addon below the RD authorization box their’s another box that is saying to enter a token . Am I missing something ?
My token loaded automatically once I added the device authorization code. I didn’t even have to copy and paste.
I cant find a link for the 2024 version, i have mediafusion and annatar installed also torrentio.
For me the Lime Torrent one was the 2024 copy. Was mislabeled.
Thanks @Miki will have a look later.
Yeah, limetorrent one plays the 2002 Jim Caviezel one. The first one is the 1975 film, and the other one isn’t there.
Limelite was mislabeled for me. As I mentioned. Although it says the 2002 copy it played the 2024 copy for me.
Hi Miki. Are you sure it was the 2024 version you watched? I have now spent the last 2 hours looking for that link you played from. I only get 1975 and 2002 versions.
Yes it was the 2024 version.
I was scrolling through stremio last night and saw this listed.Is it in english?
Yes sir. I thoroughly enjoyed it.
