I’ve started using Syncler+, still learning the in’s and out’s. I’m having a problem with shows just dropping out. It doesn’t matter which package I use for links, or which link. Any suggestions?
What device are you using it on? I havent had that issue at all, it sounds more like a high storage or ram issue… something conflicting maybe. Which player? Exo or and external?
I’m using a FireTV box, I still have plenty of space.
I think I may have fixed my problem. I reinstalled it and now it seems to be OK. I was reluctant to do that because I couldn’t find my plus passcode at first. Guess I should have tried that before asking.
Thanks for your quick response!
Its okay to ask, yes we should do all the steps but sometimes in the moment we forget. If there was anything i can do before reinstalling i will do it becuase its a pain. Im glad its working for you!!
