Hello! I’m a Syncler Plus user on Firestick. I have it installed on 2 firesticks, one brand new stick where it operates fine and normal.
On the other older stick it crashes randomly and gives a message of Player cannot play video, you can then start it again and its fine and does it again.
As mentioned using Syncler Plus with Real Debrid. Any advise?
I have had the same problem try changing your player to exotic under the settings. It sometimes still does the player not working but if I select a different stream it works for me. Good luck.
