I use an ONN box. I am looking for an easy to use app that will “clean” things up every once in awhile. Any suggestions?
DefSquid is a great app that does several things.
Sd maid is also good.
DefSquid is easy to use and will also check apps for virus.
I’ve never been able to enable all the permissions with SD Maid on my ONN 4K cheapie.
Get the pro version. One of the unlinked codes have it. And the rai has the perimum version.
Is this use only for cell phones or can you use it on firestick.sd maid
