SurfShark stuck at login
SurfShark won’t allow me to Login I’m stuck at VERIFY YOU ARE HUMAN. might there be another way to add SurfShark to a new device?
What device are you using? SS has a code login on any device as long as you’re logged into one
Login on line using your email address and password, then you can add the new device.
I finally figured it out I now have Active SurfSafe thank you. Now I’m trying to figure out how to do the Kodi Build. When you’re not tech savvy it’s challenging and takes longer but I’ll get there. A Troypoint video would be great
What Kodi build are you referring to? Or did I miss that?
I just loaded a new build and it working fine
