Surfshark "Clean Web" blocking IPTV services
Must have the desktop app not the mobile one. Try this one.
https://files.catbox.moe/7ybx9z.apk
Thank you. I will give it a go.
Thanks for the info. That’s what I thought but just wanted to be sure.
I have 4 IPTV service Surfshark has started to blocking them. This started about a week ago when it hit my first IPTV program. Then this week it hit 2 more. These are some well known programs that Troy recommended. If I cut the Surfshark off the picture jumps in. Any suggestions?
Turn off ā€œClean Webā€ setting and use Latham, NY as your location. Everything should work fine after that.
My Surfshark is blocking three of my IPTV programs. It started last week it blocked one of my best programs. Then this week they blocked two more programs, the only way to look at those programs. I have to cut my VPN off. Do anyone have that problem? If so, what’s the solution did you take?
ISP Settings Locator Guides Link for fixing ISP provider blocks and the VPN security features .
I started having issues with SurfShark about 6 months ago or so. I run my VPN client on my router so turning off CleanWeb wasn’t an option. I was reconfiguring locations just about every other day. Finally, I switched to IPVanish and haven’t looked back. I have a 2.5G fiber connection and my Formuler device is limited to a 1G connection from my hardwired mesh node with a 2.5G bachaul. My speeds through Analiti with VPN on are on average 850/425Mbps.
Thank you!!! You find the solution!!! I have 5 days with the same issue… I can’t figure im looking everywhere until I’m see your post… Thank you again!!!
welcome
You are very welcome, glad it helped!
I also have the same problem except my Clean Web was not on. I’m at my wits end. My iptv service has been trying to help me. I had a trial vpn service and it worked fine. Guess I need to give up surfshark and find another service. :sleepy_face:
Try proton free VPN and see if makes a difference Here you just might have to get a new vpn ,SS did not work for me
@Okiegal , have you looked at @TROYPOINT,s link that @Miki posted in the 3rd reply of this thread….Troy talks about this and there is a video in there as well….it might help….
Try using Latham, NY as your VPN location. Some IPTV services don’t work with many of the US cities. Mine only works with Latham, plus a couple other US cities, as well a Andora & Singapore. It is better to use US cities that are compatible because it is easier on your cable modem, if you have cable internet. Changing VPN provider shouldn’t be necessary. The problem is with your IPTV service, not your VPN.
It hasn’t happened to me (Ireland). Everything still works, even with that turned on.
Oh …dammit …I’ve just tempted fate :confused: I’ll update if I have an issue.
Running Tivimate on an old 1st gen Nvidia Shield.
When using SURF SHARK with Syncler and Streamio using Torrentio and Premiumize most often I have to turn off VPN to get streams. I’m not alone with this issue. Are there settings in Surfshark to address this issue or do I have to change the VPN service?
Might make sure clean web is off in surfshark and try .
I’ve heard that the clean web setting can be a problem and that it’s recommended to turn off.
The other thing (which I do with Premiumize & Surfshark) is to go into Surfshark features and then enable the bypasser setting. You can then add Stremio as a bypass app. This will keep Surfshark turned on for your IPTV but will allow Stremio to bypass VPN. That can help with compatability issues.
But if you do that and do not use strictly a debrid service, and nothing else, you leave yourself open to scrutiny especially if watching Copyrighted material and not just those in the public domain.
