I’m not using Surfshark, but the VPN I do use has what they call “Split Tunnel”. I have one bank that needs this and several others that do not. Just depends on the bank.
Sounds good but that’s as far as it goes! Anything with my bank requires the VPN off are it’s no connect.
Try Bypasser in your VPN settings and enter the apps or websites that’s not connecting and you should be ok hopefully… It worked for me
Same for me…i just use Bypasser in SS for sites i trust and it work’s for me
