Miki I am recently testing the waters of Stremio, I installed the MX player but do not know how to link it to Stremio. Can you help?
Personally I wouldnât bother. The player in Stremio works great, but you can go into the settings in Stremio>playback>Default Player>and then choose External Player
More and more im finding that stremio or Kodi will not have good sources for my shows and i have to get it from IPTV VOD.
I wonât bother than I trust your opinion. It does seem to play very well. Do you recommend real debrid?
I have RD and it adds an extra excellent source for my Movies and Series.
Kodi has that built in Audio Settings, which is very handy.
Thank you very much. I will try it!
Earlier, I meant to say I wonât bother then I trust your opinion. Iâm going to try a few of these things. I appreciate the advice itâs uncharted territory. I have IPTV but it doesnât have a good choice of movies. Thanks for the help.
