Stremio issue no streams were found
Good news! Torrentio has returned!
yep good news :+1:
Yes it has.
I downloaded media fusion to my stremio but I seem to be getting more links on the puter , totally different than my stremio on the onn pro Why is that
The interface may be different but the settings should be the same. Now just for clarification you don’t download media fusion you install the addon.
I went to the stremio community on puter. Put media fusion on my puter and configured for debrid and etc. the add on is showing installed on stremio on my onn pro, but don’t seem to be links, but my torrentio add on back up as you know. Can’t you run both for links ?? Or did I screw up something
I have had a similar problem in the past, you search for 3 or 4 shows and not one stream is found on shows you know should be streams for. Simple do a hard boot of device and I always go ahead and reboot the router as well and poof were back in action. When in doubt reboot! Has anyone had any luck with Orion? I used to use it all the time and have it set up in syncler and stremio… works in syncler but stremio doesn’t find anything not sure what is happening with it or I’ve not set it up in so long i’m missing something.
Thanks for the update, any changes that you know of with the set up?
I use to use orion. It does occasionally find the odd link, but not very many. I suspect the premium plan might do better.
You can run as many addons as you want. I am not having any issues with finding source links.
No. Mine just started working again; didn’t make any changes.
this could be the way stremio was setup from the beginning with Torrentio and addons
