Streaming apps for android box
Express packages are better than Kosmos, but you can only get Express with Syncler +.
No the newer syncler tutorial Troy did has the provision syncler installer which it downloads a fully configured syncler app
This is download
Any confusion just pm me I’ll walk you through step by step I got you I do stuff like this everyday for people I’m a consultant for affordable cable/streaming services like real debrid or IPTV there’s millions of people out that have no idea they can stop overpaying for their entertainment
I tried to install the provisional syncler app as described in the video.But seems its also geared to a RD account and syncler plus. Can I use this app for free all around? BY installing it and using packages to get workable streams? Or is this just for RD and a plus account?
You can use free Syncler and put 1 Kosmos package for the provider. You don’t need RD, but boy, it sure helps.
(Express packages are premium)
Best Syncler Provider Packages for Kosmos & Express 2022
I installed the Kosmos package. Now all the providers in my repository are those installed or do I have to click on each one to install them?
If you dont want to use real debrid then stop trying with syncler. Syncler plus with real debrid is the best option.
If you are looking into free options stremio is probably the best case use it with a vpn.
There is only one free provider… kosmos. Its in the install guide too
Thanks for all the useful info. I’ll give it a go and worst case ill get RD again.
