I expanded my Fire Stick storage per TROYPOINT instructions but my internal storage is not decreasing. I cannot figure out what I am doing wrong. Can anyone assist me please? Thank you in advance.
Not sure if this will help, but on my Gen2 fireTV, to manually move them to the SD card is via Settings/Applications, then choose the app and there’s an option there to move it. If the app is on the SDcard, then the option changes to move it back to the main device.
Hope this helps.
Thank you very much for your response. I do appreciate it. I am not aware of that particular option but I will certainly check it out. Have great day.
