would like to use a sd memory card to expand the memory on my android box and would like to know how to do this - please give step by step instructions including any changes in settings - thanks
Turn your device on, plug in the sd card into it’s slot, follow the on screen prompts. That’s all I had to do on my Mecool KM2, but that doesn’t mean other stbs will be the same.
