Can someone explain to me if the firestick will work with starlink internet and should I use it instead of the internet services?
The firestick connects to your internet no matter the Internet Service provider. So if Starlink is your ISP then you can use ethernet to the starlink box or WiFi if it’s on and enabled. Same goes for other ISPs.
Thank you. I appreciate your help.
