Is it possible to sort and move channels within my favourites on Live or EPG?
If you are using TiViMate then yes you can. Settings>pick the playlist you want and click on it>in the epg, find the channel you want to move, highlight it, long press the enter to bring up settings on the right>scroll down to "All playlists • Favorites " >Reorder channels, click on it and follow the on screen prompts.
