SmartTubeNext Search Not Displaying
installed this. works fine, but there is no ‘search’ that i can find.
did i miss something? maybe there’s a better alternative?
What are you running it on? I have it installed on a few devices and there’s a search on the top left
Click on the Magnifine.glass at the top left corner of the screen .
i know about the search magnify icon. it’s just not there. all the other categories like news, gaming,music,etc. appear. maybe if i uninstall then reinstall? now that i know it should be there, i’ll try again. thank you, quest
Perhaps your screen needs scaling? The search may be “off” the visible screen.
another good idea but i’ve already tried it. later today i’ll reinstall and try again.
Settings for search will fix it. I did something and it now works. I think voice search has to be turned off?
