Getting an error message on my screen on Nvidia shield, Something about a problem with smart tube next and to forward the message to Nvidia. It started after I did the recent update, Anyone else having this problem and if so do you know of a fix.thanks as always
Try uninstall and reinstall latest version. Something probably happened during the update process.
Excellent,will do ,thanks
