Setup Downloader for pc
Upped My my gaming to a18” area 51 computer.
And during my gaming, so I decided to plug up stream and good things going on on the end of it, but I can’t get the downloader on the PC. I’ve downloaded it from every place that says download it and he will not download and I’m not sure how to get it on there. Please let me know and I did check to see if there was anything on setting a PC up with downloader but I couldn’t find anything and if there is, I’m sorry my bad forgive me. Pray y’all have a very blessed weekend.
@tghopkins , not sure if this will help but…
https://www.techkings.org/threads/adding-downloader-to-my-pc.172214/
Read all the post, there’s different info…
@tghopkins I have downloader on my pc. But I also have Bluestacks. Which is a gaming app. I used it to install different apk’s on my pc. I installed downloader app through that. FYI I’m not a gamer but there were a few apps I tried installing that said for windows but got prompted to install Bluestacks for them to work which I did haven’t had any issues for now anyway :slight_smile: Seems to work well just a thought
You can use downloader codes to download apps onto your PC (aftvnews.com/[code]) but they will be android apps - won’t run on a PC (unless you install an android emulator).
Thank you so much :rose::heart_exclamation::folded_hands::heart_exclamation::rose:
Thank you :rose::heart_exclamation::folded_hands::heart_exclamation::rose:
